VeriStand
Problem deploying system definition from command line and through .NET API
I would like to interact with a system definition programmatically. As a first step, I am trying to deploy a system definition from the command line as follows:
> veristand-server.exe start
> veristand-server.exe deploy "test.nivssdf"
This deployment fails.
However, when I deploy the same system definition from VeriStand and from the command line, do
> veristand-server.exe status
Also, when I do
> veristand-server.exe undeploy
it successfully undeploys. Any ideas on why it is not able to deploy, but can undeploy?
When I try to deploy using the .NET API, I get the following error:
Unhandled Exception: System.Exception: FFFB4D55: NI VeriStand Engine.lvlib:VeriStand Engine Wrapper (RT).vi >> NI VeriStand Engine.lvlib:VeriStand Engine.vi >> NI VeriStand Engine.lvlib:VeriStand Engine State Machine.vi
But when I undeploy using the .NET API, that works.
So, deploy doesn't work from the command line or from the .NET API, but undeploy works both ways.
Further, when I deploy through VeriStand, and connect using the .NET API to the deployed system definition, I get the following error.
Unhandled Exception: System.Exception: FFFB4E36: DataServices.lvlib:ERunConfiguration.vi.ProxyCaller >> DataServices.lvlib:ERunConfiguration.vi:3090002
Any suggestions? Thanks.
Message 1 of 10
(1,161 Views)
Try Running VeriStand Operations Using the Command Line
Start with the Engine Demo example.
https://tmesystems.net/
Message 2 of 10
(1,128 Views)
Running VeriStand from the command line like so
> VeriStand.exe /deploy "system definition"
simply starts VeriStand. It only deploys that system definition from the command line if it is already open in VeriStand. This is not the behavior documented in the link you had referred to. I wonder what might be going on.
Message 3 of 10
(1,121 Views)
I noticed this as well.  The procedure in the help documentation for running VeriStand headless doesn't make any sense.
Trying to run VeriStand headless just opens the GUI.
veristand-server.exe doesn't provide the capability to deploy a system definition file to both the gateway (host) and the engine (real-time target).
This is an issue with VeriStand software.
I don't think NI has actually walked through their own procedure or followed any of their own instructions. Because  if they did, they would immediately find out their procedure and software doesn't work as described.
Message 4 of 10
(1,109 Views)
I have been able to make some progress.
First, from here, change security so that multiple hosts can connect to the same target. I am interpreting this as the VeriStand GUI is one host and the program calling the .NET API is the other host. When I do this, the program calling the .NET API is able to connect to the target system definition and interact with it.
I adapted the example code from here as below, and it does the job.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using NationalInstruments.VeriStand.ClientAPI;
using NationalInstruments.VeriStand;
namespace MyNamespace
    class Program
        static void Main(string[] args)
            String logTriggerCmd = "Aliases/EDLTrigger";
            String logCommandCmd = "Aliases/EDLCommand";
            uint timeout = 60000; // connection timeout
            //path to the system definition file.
            String sysdefPath = "C:\\Users\\me\\mysystemdef.nivssdf";
            String gatewayIP = "localhost"; //IP address of veristand gateway the system definition will be deployed to.
            //make new workspace object
            Factory FacRef = new Factory();
            IWorkspace2 Workspace = FacRef.GetIWorkspace2(gatewayIP);
            // Connect to the system definition
            Workspace.ConnectToSystem(sysdefPath, false, timeout);
            Console.WriteLine("Connected successfully");
            Console.WriteLine("");
            // Start logging
            Workspace.SetSingleChannelValue(logTriggerCmd, 1.0);
            Console.WriteLine("EDL triggered");
            System.Threading.Thread.Sleep(10000); // Wait 10 seconds
            // Stop logging and close file
            Workspace.SetSingleChannelValue(logTriggerCmd, 0.0);
            Workspace.SetSingleChannelValue(logCommandCmd, 2.0);
            Console.WriteLine("EDL closed");
            // Disconnect from system
            Workspace.DisconnectFromSystem("", false);
            Console.WriteLine("Disonnected from system");
There are few remaining issues.
1. Still not able to deploy from the command line using veristand-server.exe, or programmatically using the ,NET API call - however, this is not a major issue for me, I can deploy from the VeriStand GUI and doesn't affect my workflow
2. My main remaining issue is calling
should simply disconnect without undeploying, but is undeploys. Any suggestions?
Message 5 of 10
(1,097 Views)
Hi BigApple0, mvsiva,
To run VeriStand headlessly, follow the documentation at "Running the VeriStand Gateway Silently". This brings up the Gateway and lets you connect to it via APIs without bringing up the VeriStand application.
To run/operate VeriStand application from command line, follow the documentation at "Running VeriStand Operations Using the Command Line". This is not the headless mode of operation.
However, I acknowledge there is scope for improving our user manuals 🙂 we are working on it.
If you are using a windows target, DisconnectFromSystem will undeploy regardless of the undeploy parameter.
If you are using a NI Linux RT target, DisconnectFromSystem only disconnects if you specify undeploy as false.
Calling VeriStand-server.exe status at this point will say "Nothing Deployed" because we just disconnected the gateway from the target. This is accurate as the gateway is now free and not connected to any active deployment. But the target will still continue to execute the system.
To verify this, try calling ConnectToSystem with deploy set to false and it should work.
Let me know if this is not the case with you.
Message 6 of 10
(1,058 Views)
Hi ShreeHarsha94,
Thank you for your response.
I am using an NI RT Linux Target.
The behavior described in the documentation you had linked is not what I am getting.
  1. I am not able to use veristand-server.exe deploy to deploy (however, once deployed using the GUI, I am able to use veristand-exe.undeploy to undeploy)
  2. I am not able to use ConnectToSystem with the true argument to deploy; again, however, once deployed using the GUI, I am able to use ConnectToSystem with the false argument to connect and then change channel values etc. as in my code above.
  3. Using DisconnectFromSystem with the false argument not only disconnects, but also undeploys. I can check that is does from either the gateway, veristand-server.exe status, or in the GUI.
In summary, here is my workflow
  1. Deploy using the GUI (keep GUI running)
  2. Use the API to connect to the system definition and perform different operations
  3. Disconnect, causing undeployment
The inconvenient thing for me is only the fact that disconnecting causes undeployment.
Message 7 of 10
(1,042 Views)
Yes, this doesn't work properly.  Has anyone from NI actually tried this?
Message 8 of 10
(500 Views)
Hi mvsiva,
What version of VeriStand are you using?
In your original post, you mentioned getting error 0xFFFB4D55 from the ConnectToSystem method. This error corresponds to VeriStand error code -307883: Cannot deploy project because the system definition file contains scales but the project does not contain a channel calibration file (.nivscf). Delete the scales from the system definition file and redeploy.
As discussed in this KB article, if your project contains scales, you need to specify the .nivscf file in the deploy options. Here's an example in LabVIEW, but the same would apply to calling the .NET API from any other language:
For issue #1:
I just tested starting the server and deploying using the veristand-server.exe and it worked fine for me to deploy to a Linux RT target:
If the deploy command is not working for you still, what error do you get? Does it display a hex code?
I'd recommend checking the following:
  • Ensure that the veristand-server.exe is not being blocked by firewall or antivirus software. Even though some functionality (like undeploy) works fine, the deploy command might be being blocked.
  • Check Windows Event Viewer to see if anything is being logged to the Application or System logs that could explain the issue.
Issue #2:
I also tested using the ConnectToSystem method with the Deploy option set to true, and this worked fine for me as well. I'm guessing that whatever is preventing you from deploying with the CLI is also causing this method to fail, so I'd recommend the same steps as above.
Issue #3:
DisconnectFromSystem is working properly for me as well. If I set undeploy to False, the gateway disconnects from the target but I confirmed with a monitor hooked up to the target that the System Definition continues to run after I disconnect. Also, if I open the VeriStand GUI and go to Operate>>Connect I am able to connect to the running target without deploying.
Let me know if this helps.
-Jordan
Message 9 of 10
(259 Views)
veristand-server.exe does not accept an argument for specifying the calibration file path as of today. This might be the cause of failure.
I would recommend using the ConnectToSystem API specifying the calibration file path in the interim until this gets added in an upcoming VeriStand release.
Message 10 of 10
(249 Views)
