VeriStand
NI Veristand datalogging API's labview control
     I am running into an issue with trying to capture data with NI Veristand through the Labview NI Veristand datalogging API's.  As you can see from the attached document I am getting an error while trying to start the task.  It only happens when I try to trigger the task off a user channel deployed on the target.  I set the start trigger to immediate and indefinately respectively I don't have an issue, only when I try to trigger off a channel in the system definition file.  I hope my attachement and information here can give you an idea of my issue and maybe a workaround or solution.  Thanks.
(1,481 Views)
Hi there,
Error -307860 means the following: The specified trigger channel does not exist.
How is the trigger defined? Check your path name in the reference channel name of the trigger VI’s.
(1,309 Views)
