VeriStand
Main Menu values
Most of my Custom Devices retain last values selected on the Main Menu, but I have some that do not.  Is Veristand expected to retain the values, or should I be using VI "Make Current Values Default" to force the behavior.  If Veristand does have the option to retain values, is there a setting that I am missing?
(6,106 Views)
Hi DinaDemara,
It looks like the VI you're looking for is this one:
http://zone.ni.com/reference/en-XX/help/372846H-01/veristandmerge/vs_set_custom_device_channel_defau...
Joel I.
(6,070 Views)
Are there any examples using this?  All the Main Menu examples just seem to show vs_set_item_property.
(6,065 Views)
(6,065 Views)
DinaDemara,
When you say "Main Menu" do you mean the controls on your custom device main page?
If so you will need to make sure that the values the user inputs into those controls are stored somehow, likely as properties of that page.  Then you will have to read those properties and write them to the controls when the page launches.  So in additions to the Set_Item_Property VI, you will need to use the Get_Item_Property VI at the beginning of the custom device page VI.
The NI-provided template for custom device pages demonstrates this functionality with the description control.
Chris
Certified LabVIEW Architect
Certified TestStand Architect
(6,054 Views)
