VeriStand
Labview simulation model problem
i have a problem with including a really simple LabVIEW model into VeriStand. You see the block diagramm below. I implemented the boolean as switch in the VeriStand UI, but when pressing the switch, there is no reaction.
Could it be, that VeriStand has a problem with finding the location of the deposited VI?
(2,746 Views)
Is your target (where the model runs) Windows? If not how exactly should the code running on RT target locate and load VI stored somewhere on your host PC?
CLA, CTA, CLED
(2,726 Views)
Oh, yes i think you are right. No it is PharLap. Do you have a idea, how i can fix this problem?
(2,715 Views)
Well, it depends on what is the ".\test_CANoe\Measurement Start.vi" doing. If you are trying to integrate a control API to handle 3rd part stuff, you might consider to implement a Custom Device (formal name for custom plug-in for VeriStand). Maybe you can reuse or modify some of the existing Custom Device (see https://github.com/NIVeriStandAdd-Ons). In my eyes you are working on a fairly complex functionality for which LV model is not the right way to go...
CLA, CTA, CLED
(2,699 Views)
