VeriStand
Is there a way to log all traffic on a CAN port in VeriStand?
Could you please instruct how to set up a LabVIEW step FTP the files off of the target in order to make them available for analysis in windows? I'm using Max FTP client to transfer files,but it depends on manually click.I'm nou sure what file format I want the files to be saved as,I just want to analyse the files ,maybe put the data into an array so that Teststand can test whether has the number I want. Tnanks!
Message 11 of 20
(3,365 Views)
You can find an example of programmatically FTPing in this KnowledgeBase
Miles G.
Staff Applications Engineering Specialist
Message 12 of 20
(3,346 Views)
Thanks for your patient answer!I can solve the problem that uploading files from remote system.But I don't konw how to analyse the logging files in my local computer whose format are .ncl with Teststand.I just need the data in the frame . For example, I want to find whether the data in the frame has the code "22 01".I'm using teststand 2014. Looking forward to your reply!
Message 13 of 20
(3,328 Views)
Are you using NI-CAN or the NI-XNET driver? I usually expect ncl files to be associated with NI-CAN applications. This document can give you some more information about how to intereact with .ncl files.
Miles G.
Message 14 of 20
(3,307 Views)
I'm using NI-XNET driver to send and receive CAN frames,also log them.In my opinion, I want to use Labview to exteact the data from the NCL files and put them into an array.Then teststand can call the Labview VI and get the array.
Message 15 of 20
(3,294 Views)
NCL files are binary files so they will not be human readable. What data are you trying to pull out from them? Depending on what you are trying to extract you may be able to use the specifications in the document I linked in my last post. An alternate option is logging to a TDMS file. Finally, since you are using VeriStand you may be able to use this add-on in order to interpret the files.
Do you think any of these would suit your needs?
Miles G.
Message 16 of 20
(3,283 Views)
Hi @blackburnite
I would be interested in the logger for CAN to mf4/asc.
Would it be possible to the the custom device?
Best regards
Message 17 of 20
(1,504 Views)
I can look to see if I still have that code, but I haven't used it essentially since 2015 so no promises and for sure it will be an "as is" code drop.  I can't support it much.
I saw my father do some work on a car once as a kid and I asked him "How did you know how to do that?" He responded "I didn't, I had to figure it out."
Message 18 of 20
(1,491 Views)
Hi, Is it possible to shared the code? Or Could you please explain how you have edited the existing data logger CD?
Message 19 of 20
(212 Views)
You can run NI-XNET Bus Monitor on the host PC while VeriStand is running. No custom device is needed.
Log Bus Traffic with NI-XNET Bus Monitor While Running NI-XNET Application
https://tmesystems.net/
Message 20 of 20
(193 Views)
