VeriStand
IronPython script error code 0xfffb4e36
import time
import NIVeriStand
from NIVeriStand import NIVeriStandException
wks = NIVeriStand.Workspace2("localhost")
SYSDEF = r"C:\Users\Public\Documents\National Instruments\NI VeriStand 2013\Projects\Pump\Pump.nivssdf"
print 30*"+"
wks.ConnectToSystem(SYSDEF, 1, 60000)
print 30*"*"
time.sleep(5)
I couldn't find out what this error code is from the NI web or help file.
Any idea?
(6,549 Views)
Accepted by topic author xhuang2
It seems as though there is already a SDF deployed.
Before you call ConnectToSystem you could check for a deployed SDF and disconnect it:
	state = wks.GetSystemState()
	if (state['state'] != 0):
		print 'Error! System state not expected!'
		print "Undeploying SDF: " + state['systemdefinition_file']
		wks.DisconnectFromSystem('',1)
(6,534 Views)
Hi UKCraig,
I did as you suggested.  The weird thing is GetSystemState returned a non-zero value, which I could still read out the correct channel value Smiley Sad
(6,522 Views)
Did you try disconnecting as I suggested above?
(6,499 Views)
Hi UKCraig,
You're right.  When I used disconnecting, it worked!  It will first disconnect the system and deploy it again.   If I'd like only to read some channel values out from the running workspace GUI, I don't need to use the connectToSystem methon in python script.
Thanks a lot!
(6,481 Views)
