VeriStand
Input/output data serailization of generated model from LabVIEW VI
I implemented LabVIEW model and I generated model from VI, that should be used on VeriStand (Tools ->NI VeriStand -> Generate Model from VI) and I chose to create dynamic lib for Linux. I found out what are supported types for inputs and outputs, but I'm interested if there is any documentation about input/output data serialization?
For example, if 1d array is used as input/output, default values (which mean size and actual values) have to be set in order to generate model from VI. That means if I set input array with 3 elements in LabVIEW model, it will later (in dynamic lib) use 3 elements although I want more/less elements. Is there any solution to this problem? Also, if there are more than one output, I would say that it store them in double outputs[] from the last to first connected output from LabVIEW model and I have to know size of arrays or whatever in order to pull out elements I want. I couldn't find any documentation on this topic, so I would appreciate any kind of help.
Thanks!
(1,735 Views)
See LabVIEW VI Model Conversion Preparation
https://tmesystems.net/
(1,707 Views)
