VeriStand
How to change CAN-FD "Sample Point" using VeriStand .NET API?
Trying to change 'Sample Point' under CAN Port Spec using .NET API. Don't see any options.
Any suggestion?
(910 Views)
Accepted by topic author mtitoo@archer.com
You cannot set the Sample Point property directly. Instead, you should write the hexadecimal value from the custom baud rate dialog to the FDBaudRate property. See How Can I Set Custom Baud Rates on NI-XNET Devices?
https://tmesystems.net/
(883 Views)
Great!
(848 Views)
