VeriStand
How can I add CAN port of XNET on VeriStand 2015SP1
I'm using VeriStand2015SP1. Then I wanted to add a CAN port simply on XNET but it doen't allow me to click [OK] button even though I put an unique CAN port name and normally exsisting XNET database.
Is there any special rule to name  XNET CAN port name there?
(2,820 Views)
Since you are using Veristand 2015SP1, complete the following steps to discover all NI-XNET devices
1- Display the system Explorer window.
2- In the configuration tree, navigate to Hardware>>Chassis>>NI-XNET
3- Click the Hardware Discovery Wizard button and follow the instructions
This helps you to add the ports automatically
(2,798 Views)
