VeriStand
Get output log from Veristand on Windows
I'm running my tests on a Windows agent controlled from a CI/CD server. I use command line to start VeriStand and deploy:
$result = Start-Process veristand -WindowStyle Maximized -ArgumentList "-OpenProject C:\bitbucket\VeriStand\Mid0_EEC.nivsprj -deploy"
But sometimes VeriStands fails to deploy. There is a tab called OUTPUT that has the VeriStand application log showing some information about what happened.
It is visible when the UI is open, but I have no access to it when I run from remote command.
Where does VeriStand store the application log on the local system? In this case I can collect some data to log.
Message 1 of 1
(876 Views)
