VeriStand
DIO configuration on compact with Veristand
I've a cRIO 9024 with a NI 9401 card ( DIO 5 V TTL), I've created the FPGA code ( see picture below) and the XML file to use it with Veristand.
The compilation and deployment works, but I can't change the state of my output on the card.
Could you see the little FPGA code and XML file to help me to find the error ?
Regards
Cyril
(6,242 Views)
Hi Cyril,
Thanks for posting on our forum.
Could you tell us if you cannot change any ouput at all, or if it's a problem only with one?
Regards
(6,197 Views)
Accepted by topic author Cyril_25
Hi, thanks for your answer.
Actually I have found the problem.
In the properties of the card on the labview project, the DIO 0:3 was not declared as output.
I was sure it was an XML problem but I was wrong.
Cyril
(6,168 Views)
