05-05-2016 10:49 AM
Implemented changes for the custom data change. Worked. Now the channel mapping are saved once set. Thanks...
05-05-2016 11:14 AM
Channels are saved, but now dial changes are not triggering channel changes...
05-05-2016 11:39 AM
One needs to have all signals for CAN messages mapped to channel for the tranmission to work.
09-09-2016 04:45 AM
I'm having the same issue that you faced.
While creating a custom control for NIVS, I cannot save the bindings of the channels when I close the workspace of NIVS.
It seems that now you succeed to save channels mapping.
Could you please share an updated version of your VI in order to see how you did it?
Thanks in advance.
Regards.
PS : I attached my VI for information purpose (LV/NIVS 2013 SP1)
03-08-2017 12:32 AM
I'm new in VeriStand and Custome Objects and I have the same issue as described here. When I close the workspace an re-open it, all channel bindings gets lost. I have the same VI structure as gaetanR has prvided here.
Are there any solutions what's wrong in the VI? I'm using LabView 2015 / Veristand 2015 SP1
Thanks in advance!
Regards
03-09-2017 09:24 AM
I noticed that while you seem to be trying to do the same that is exposed in this tutorial, you have several differences, including initialization and user events usage. Can you try with the steps from the document?
You can actually upload the code and it would be easier for us to provide advice that with a screenshot. ![]()
04-05-2017 11:29 AM
Webserver81 maybe you already fixed your problem as your post is 1 month old. I upload here what I did to solve this issue.
I changed my Custom Data cluster to vehiculate the channel names in order to retrieve them from the initialization part of the vi. In the state machine part, the Custom Data shift register starts with the saved values. I just focused on the channel binding part, so I get rid of min/max parameters, etc.
It seems to work well like that except one point : I found out that when I deploy straight after adding my workspace object, only the first channel works properly. Then if I close the workspace and open it again everything works fine... This is strange (maybe you'll find out why when looking at my code) but not such annoying...
I hope it will help!
