VeriStand
Control Frame CAN in a model
I have to check 112 CAN frames, each frame has several signals. I want to know if there is a solution to do it in a model without mapping, such as manipulating with the property node / Invoke node (if it's possible how to retrieve the Xnet refrence).
(2,701 Views)
I guess it may be possible doing a LV model, I've never tried. What is the reason behind this question because NIVS already include support for XNET boards inside the System Definition File.
Paolo_P
Certified TestStand Architect
Certified LabVIEW Architect
National Instruments France
(2,637 Views)
thank you for your reply.
The reason is that I have to manipulate several CAN signals in coherence with my voltage profile respecting the ms, given that on labview I do not know how to map beyond 14 inputs. I wanted to do the manipulation directly with node of properties recovering the reference of the Xnet.
(2,632 Views)
