VeriStand
Compatibilty Labview and Veristand version
Ist LabView 2018 compatible with Veristand 2016?
in fact ist a higher LabView Version (LabView 2017,Labview 2018) compatible with lower Veristand Version (Veristand 2016)
best regards
(3,610 Views)
Hey dkolins,
You should use the same version of LabVIEW with the same version of VeriStand. Using LabVIEW service pack versions should be fine also. For example, if you are using VeriStand 2016, you should use LabVIEW 2016 or LabVIEW 2016 SP1 with it.
Andy
PSE
(3,570 Views)
