VeriStand
Compatibility UI Manager
when opening a VeriStand project, a loading error is displayed stating that the version of VeriStand.UIManager is not compatible. How can I update the UIManager from version 6.1.0.52304 to the version shown in the screenshot? 
(2,635 Views)
Hello mihamm,
The issue rises up spontaneously or after some action and/or software installation?
Have you tried to reinstall or repair the program?
__________________________________________
The best way to thank, is to give KUDOS
(2,414 Views)
Thank you for your answer,
the problem has already been solved. The reason was an incompatibility between Veristand and VeriStand Engine.
(2,399 Views)
