03-08-2018 05:54 AM
Hello everybody,
does anybody know how to Change the color of the menubar in VeriStand. I know that you can change the color of the "upper part" of the menubar. It works by writing: "menubar.background=0000FF" in the "NI VeriStand.ini" Folder.
But the other part of bar does not change the color with this solution.
Have anybody an idea?
03-08-2018 08:21 AM
I've not used VeriStand so I wouldn't be much help but I would recommend that you post your question in the VeriStand forums: https://forums.ni.com/t5/NI-VeriStand/bd-p/440
People who do know VeriStand are more likely to see it over there.
Cheers,
03-13-2018 07:23 AM
The toolbar is written in LabVIEW, unfortunately there's no way to change its background color like the menubar. Is that a requirement for your application or just a style concern? You will need to use another environment to design the UI you're looking for here (using the VeriStand API calls from LabVIEW/.NET/IronPython/others...)
--Eric
Eric M. - Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer - Certified LabWindows™/CVI Developer
Neosoft Technologies inc.
