09-17-2019 05:49 AM
I created a Calculated Channel (MyCalcChannel) and I used Condition like setting.
So MyCalcChannel is 0
if MyChannel is 0
then MyCalcChannel is 1
else MyCalcChannel is 0
and until now there aren't problems...
Now, In my my workspace, I have the MyChannel control and MyCalcChannel indicator. If I change the MyChannel value, the MyCalcChannel works properly, but If I change MyCalcChannel I supposed that the clock after it takes the rigth value, but it doesn't.
Why? I hope it is clear otherwise I'm going to send an example
Thank you Fabio
09-17-2019 07:35 AM
I'm wondering how you managed to change the value of a Calculated Channel from the workspace? It should not be possible as all calculated channels are read only ...
09-17-2019 07:53 AM - edited 09-17-2019 08:09 AM
Thank you very much for your answer. In fact when I change the Calculated Channel Value I can read an error... So the effect that I can read is that the control/indicator change value but the channel value is the same...
I don't like very much this effect. If I define an object like an indicator the user cannot modify its value. But that is.
