VeriStand
CAN signal reading in Veristand is not consistent
I have been observing that, CAN signal updates in Veristand takes considerable time and is not consistent. For example if some signal value changes to 1, I could see that change in veristand after 200 ms to 700 ms (time is variable), Ideally change should reflect in veristand immediately or may be within few millisecond. I am running X-Net loop at 100 Hz same as primary control loop.
Did anyone face similar issue? Please let me know the solution.
Message 1 of 1
(5,398 Views)
