VeriStand
Basic Example for VS with Python
Hello.  Anyone got a basic script for non-deterministically reading an writing to a channel in Python using the verion 2.0.x?
Even opening a simple channel reference like in the example documentation errors out with "Python.Runtime.PythonException: 'str' value cannot be converted to NationalInstruments.VeriStand.Data.DoubleValue" which is weird because if you go the ChannelReference function they specifically give an example that you pass it a str.
from niveristand import nivs_rt_sequence, realtimesequencetools
from niveristand.clientapi import ChannelReference
def readchannel():
mdlcount = ChannelReference('Targets/Controller/System Channels/Model Count')
print("This is the end")
if __name__ == '__main__':
readchannel()
The State Machine exmaple int he doc pretty much does the exact same thing when it does '
output = ChannelReference('Aliases/DesiredRPM')
Do I need to use the
@nivs_rt_sequence
decorator even if I am not doing an RT sequence?
A small example of read from and writing to a channel non-deterministically would be nice.
(4,485 Views)
I suspect this is a bug regarding version compatibility that we are currently investigating. What versions of python, pythonnet, niveristand, and VeriStand are you using? I assume you installed python 3.7 or newer and niveristand 2.0.x, which likely installed pythonnet 3.0.0.post1. If you run py -m pip list, you should be able to confirm. I would then recommend that you downgrade pythonnet to 2.5.2 as preliminary testing in our investigation appears to show that resolves the issue.
Brian.D
NI Product Owner
VeriStand
(4,447 Views)
virtual environment for reference
These were all defaults.
I rolled back to 3.0.0 and retested and still got the error.  Then I tried to go back to 2.5.2 except when i try to install I get
Installed:
4 package(s) to packages.config projects
error: [WinError 2] The system cannot find the file specified
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for pythonnet
error: subprocess-exited-with-error
Running setup.py install for pythonnet did not run successfully.
exit code: 1
[6 lines of output]
usage: setup.py [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts] ...]
or: setup.py --help [cmd1 cmd2 ...]
or: setup.py --help-commands
or: setup.py cmd --help
error: option --single-version-externally-managed not recognized
[end of output]
error: legacy-install-failure
Encountered error while trying to install package.
Updated pip, wheel, and setuptools.  Had no impact.  How were you able to install it?  Started looking into the error, but it very quickly got into a lot of tools I have never used.
(4,438 Views)
Bump.  Anyone got ideas.
(4,387 Views)
Apologies for the delayed response, we have released a new version of niveristand-python that now pins the pythonnet support to 2.5.2. Unfortunately, I suspect you are using a newer version of python that only supports pythonnet 3.0.0 (i.e. python 3.10 or 3.11). If you are using 3.7-3.8, the new version should install properly. We do intend to update our package to support the latest versions of python and pythonnet.
Brian.D
NI Product Owner
VeriStand
(4,340 Views)
Following up on this post, we just released a new version of niveristand that adds compatibility with pythonnet 3.0.1 and python 3.9+ https://github.com/ni/niveristand-python/releases/tag/v2.1.0
Brian.D
NI Product Owner
VeriStand
(3,999 Views)
