VeriStand
Alias, Scale, or Calculated Channels on Waveform tasks?
Once a DAQ Device has been setup for waveform instead of single point, is there a way to use the channels from that device for Alias, Scales, or Calculated channels in Veristand 2014?
Message 1 of 9
(6,495 Views)
Hi bleslie,
There isn't a way to use Alias, Scales, or Calculated Channels with Waveform tasks in VeriStand 2014.  The only way to do this would be to create a custom device and implement the logic.
Another option would be to set up two different DAQ devices (one configured for Single-Point, the other for Waveform) and define Aliases, Calculated Channels, or Scales for the Single Point device.
I hope this helps!
Nadine H.
Message 2 of 9
(6,468 Views)
Has anyone from NI created a Custom device that could perhaps import the configured channels and provide basic polynominal scaling?
Thanks.
Rob
Message 3 of 9
(5,471 Views)
Hi Rob,
There are a number of custom devices that are kept on a GitHub repo that you can download here: https://github.com/NIVeriStandAdd-Ons
Where are you trying to import this data from?
Kevin F.
Message 4 of 9
(5,452 Views)
I am aquiring waveform data from a cDAQ in Veristand.  I was wondering if there was a custom device that could just grab the channel references of the waveform channels, do the some kind of scaling and spit it back out as a duplicate channel.  I find it quite odd that there is no ability to scale the waveform data natively.
Thanks.
Rob
Message 5 of 9
(5,448 Views)
There is custom device like this in LabVIEW examples.
CLA, CTA
Message 6 of 9
(5,444 Views)
Thanks Jiri I can expand on this example.
Thanks.
Rob
Message 7 of 9
(5,441 Views)
Can you point us to the example you're referring to?
Message 8 of 9
(4,377 Views)
I think he might be referring to the example at C:\Program Files(x86)\National Instruments\Labview <year>\examples\NI Veristand\Custom Devices\Waveform Analysis and Generation
Message 9 of 9
(4,369 Views)
