This test returns a failure for any event structure that has a Timeout frame, but the Timeout terminal of the Event Structure is unwired:
In this situation, the Timeout frame will never run, meaning it should be removed, or a timeout should be wired to the Timeout terminal.
Follow the instructions here to install and use this test. The attachment is saved in LabVIEW 2015.
