If you need to change the ranking of an existing VI Analyzer test, here is the procedure. Note that the procedure for a global-based configuration test is different from the procedure for a VI-based configuration test:
Global-based configuration procedure
1. Open the config VI.
2. Select Edit > Show Hidden Controls and Indicators.
3. Change the value of the Test Ranking control that was just shown.
4. Select Edit > Make Current Values Default.
5. Right-click the Test Ranking control and select Advanced > Hide Control.
6. Save the config VI.
VI-based configuration procedure
2. Go to the block diagram.
3. Find the terminal for the Test Ranking control.
4. Right-click the terminal and choose Show Control.
5. Change the value of the Test Ranking control that was just shown.
6. Select Edit > Make Current Values Default.
7. Right-click the Test Ranking control and select Advanced > Hide Control.
8. Save the config VI.
