Unit Testing Group
Unit Test Tool Comparison Table
Has anyone created/seen a table such as above? I'm at the unenviable position of needing to add unit tests to 100's of VI's, CI/Jenkins integration is a MUST, as is code coverage and perhaps requirements traceability.  I've spent a few hours trying to understand the current solutions, and I think that ONLY JKI VI Tester can do everything I need?  my need for CI/Jenkins eliminating NI-UTF from the running?
(8,154 Views)
I thought NI Week 2017 had a presentation where Jenkins integration was used with both VI Tester and UTF (the example was FPGA testing). If I have recalled correctly then NI's framework is the only one that satisfies all your needs in one form or another.
EDIT: Try looking through this and then on to the links in the last slide: https://www.slideshare.net/ChingHwaYu/automated-test-of-labview-fpga-code-ci-and-jenkins-2-pipelines
(8,148 Views)
You can get all of them to work with Jenkins now I believe (certainly VI tester and UTF).
Your killer requirement is the code coverage. Only UTF gives that at the minute so it will force you down that route.
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
(8,104 Views)
Sorry I'm late to the party...
One additional note in case someone else views this thread. VI Tester and UTF are the only ones that currently provide JUnit reports that can be consumed by Jenkins' Performance plugin.
(8,019 Views)
I am definitely very very late to this party!
Beavercreek,
Do you have an update on your findings?
The only thing I had to add to your table is that Traceability to Requirements can also be done via Requirements Gateway in Caraya and VI Tester, because they are VIs and you can just add a "covers" tag to them.
If you do plan to post an updated table, I would add two tools mentioned in this group:
Assertions toolkit by Peter Horn: https://forums.ni.com/t5/Unit-Testing-Group/Assertions/gpm-p/3516217
Peter Horn works for NI, but I am not sure you would put NI as the company.
Cost: free
OO support: yes
Jenkins integration: ?? I will ask Peter to answer that one
Traceability Requirements: same as above, via Requirements Gateway by adding a covers tag
AST Unit Tester: https://forums.ni.com/t5/Unit-Testing-Group/AST-Unit-Tester/gpm-p/3454694
I will ping Dan to complete the table for this tool
I am really curious to know how your project went.
Fab
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
(7,668 Views)
The unit tester I made is very simple.
Company  Product              Output         OO Support  Jenkins Integration  Code Coverage  Additional                         Cost
AST           AST Unit Tester   txt File       No                  No                           No                       Very Simple Unit tester    0
Dan Shangraw, P.E.
(7,661 Views)
