Unit Testing Group
Testing when the expected output is an array of NaNs reports a false positive
Hi fellow Unit Testers,
I remember having this issue with the older version of the Unit Test Framework, but alas, it is still present in the new version.
A customer contacted me asking what to do, because the expected output was array of NaNs and the VI under test was returning an array of numbers and yet, the test was passing!!!
My suggestion to use as a workaround was to create an User Defined Test that would test for the array of NaNs. I was wondering if anyone here had found this issue and if you had any suggestions other than the User Defined Test.
Before someone suggests that we move to JKI VI Tester for this particular project, I can tell you that we are using UTF and not JKI VI tester because the customer is in a regulated industry.
[Edit] Cross-posted at the forums: http://forums.ni.com/t5/LabVIEW/Unit-Testing-with-Unit-Test-Framework-when-the-expected-output/td-p/...
[Edit] Here is a video describing the problem and how we are addressing it via a User Defined Test.
Fab
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
(10,449 Views)
Wow. As you know I don't use the UTF that much but that's a little scary. I would have expected that any NaN comparison would have simply failed no matter what (if they were simply testing using the Equals? primitive for any native type). But successful comparison between a number and NaN? Presumably you reported this.
The only solution I can think of is a user Defined Test with specific IsNan comparison for the one test; there are no other obvious solutions.
I wonder if the UTF has it's own set of unit tests?
(9,141 Views)
To be fair, if you have a scalar it does work, it is when you have an array of NaNs that it breaks.
Other than the tweet and the post on the forums: http://forums.ni.com/t5/LabVIEW/Unit-Testing-with-Unit-Test-Framework-when-the-expected-output/td-p/...
No. I was hoping that it would make someone at NI scare, but I guess since I present a workaround on the video, it wasn't scary enough... or maybe they thought it was a Halloween trick... anyway, I will give it a couple of days, if I don't see any movement on the forums, I will call an AE.
I do wonder as well. If it does, hopefully they will fix that unit test or add a unit test to check for this.
Thanks for validating that the user defined test would be the only way to go.
Fab
(9,141 Views)
update from the forum post. AE was able to reproduce the problem and has filed a CAR (Corrective Action Request) with NI R&D.
CAR # 554457
(9,141 Views)
Accepted by topic author FabiolaDelaCueva
Update on this issue, I just tried creating a unit test that had an array of NaNs as expected output and the issue has been solved in LabVIEW 2017 and LabVIEW 2018. So I did a search and it turns out this was fixed for UTF for LabVIEW 2016. You can find the CAR #554457 listed as fixed in the bug fixes section of the LabVIEW 2016 Unit Test Framework Readme at http://www.ni.com/pdf/manuals/375338b.html
(6,502 Views)
