Unit Testing Group
Caraya tutorial videos
Following VIWeek, @Fabiola suggested I put links here to a few demos I prepared for Caraya.
Simple Test with Caraya 1.0
The video walks through a simple project where the basic unit testing functions are presented and a file report is produced from those results. In this tutorial, I demonstrate how to build a test harness from a series of test specifications. I then produce a report using the "Test Suites" approach, which is compatible with real-time targets and runtime engine execution. The demo uses a workflow that is compatible with both a TDD (test-driven development) approach, or a divide-and-conquer approach where different teams are responsible for producing code and tests for code.
Creating Custom Test Reports (>= Caraya 0.6)
Creating custom test reports for Caraya, an open-source assertion-based Unit Test Framework for LabVIEW
Palette and VI Tree tour for Caraya 1.0 (slightly outdated, because this was shot before final release and some palettes changed)
GCentral ChampionCLA
Message 1 of 1
(3,803 Views)
