USRP Software Radio
spectrum sensing examples
I s there any spectrum sensing examples that I can use to tell me free and busy channel so I can work on a spectrum sharing algorithm
(7,861 Views)
Hi petroldevil,
Have you checked out the programs in the USRP example folder? There are a couple of spectral monitoring examples in there that might be helpful.
To find USRP examples, go to All Programs>>National Instrument>>NI-USRP>>Examples
(7,834 Views)
These examples doesnt help me to implement an enrgy dtection technique, because I cant calculate the power in a band
(7,829 Views)
Petroldevil,
Have you looked into the subVI for the Forward Powerpoint Slides? You set an upper and lower frequency threshold and then a trigger level. Might require less work to start from this than from a blank VI.
Anthony F.
Staff Software Engineer
(7,819 Views)
Is there any spectrum sensing VI for matched filter , energy detection and cyclostationary technique?
(4,070 Views)
Hi SaimaKhadim,
Could you elaborate on your question and what exactly you are looking for since those three things are fairly different?
For the matched filter you should be able to simply add a filter in front of the previously mentioned example. I'm not sure how the energy detection and cyclostationary technique are related here.
Shalini M.
Partner Development Engineer
Alliance Partner Network
(4,053 Views)
