USRP Software Radio
matlab
i had a problem when i was using matlab node inside of labview.i did some simple calculations about BER but the matlab server just kept telling the matrixs could not match to each other.
i transfer the words which the length is 736 where orignal was 731 but i used space to fill it into 736.and the receving part i get 736 words and i decoded into binary code for later BER calculations which the length of decode binary is 5152. from the transmitting part i did decode too.and i substrate them together then absolute value in the end use sum.here is the problem because it just kept telling me the matrixs could not match to each other.and i just the receving data magically changed into 736 and there is no information inside but zeros.
could anybody help me out?thanks a lot.
(6,246 Views)
subVIs are missing.
the thing is that sent or received data are in string format. you'd better make sure the length of string are as request.
(6,225 Views)
what do u mean by the length of the string?and when i sent the data the length is 731 but after receving the data i checked from matlab but there are 736 characters.btw which subvis is missing??
(6,197 Views)
Hello edwardfu,
From the first post, it sounds like the error is potentially occuring inside the MatLab Node:
Does this code work outside LabVIEW?
If it does, what data are you providing to get a working output?
How does that compare to the data you are providing inside LabVIEW?
Screenshots of a working data set and a non-working data set are very valuable.
Anthony F.
Staff Software Engineer
(6,173 Views)
