USRP Software Radio
error 74 while creating project with usrp simple streaming template
HI THERE,
I am unable to create project using USRP simple streaming template.
Error 74 occurred at Invoke Node in NI_NPW_Project Copying.lvlib:CopyUserProject.vi->NI_NPW_Project Copying.lvlib:CreateUserProject.vi->NewProjectDialog.vi
Possible reason(s):
LabVIEW: (Hex 0x4A) Memory or dv1.PNGata structure corrupt.
maysmaddy0302
(4,283 Views)
    I have the same problem, when I create  a template compactRIO project.   The software version is LabVIEW 2019 SP1 f1.
    Eventhough reinstall the whole software and driver, the problem is still there.
(4,176 Views)
What software and driver you have installed ?
bhovhann
(3,904 Views)
Hi everyone, I've just hit the same problem. Has anyone found a solution? Thanks.
(3,503 Views)
Ok, just seen the post re LabView 2020 - pity. Has a fix been issued for LV 2019?
(3,500 Views)
