USRP Software Radio
Transmit signal on different frequency steps
 I am working on Microwave Imaging using Software-defined radio's. I want to discuss something related to SDR's. I want to transmit and receive signals in the band of 1-6 GHz with the step of 100MHz using Ni USRP 2901. Main problem I am facing is how can I send and receive signals simultaneously? I can transmit signals using a loop whose index value is N=(Stop freq-start freq)/sweep step (attached screenshot ). But I can't find it the correct way. Is there any other way of doing this.
Regards
Humza Sami
(3,039 Views)
HI,
Here you can find the needed example and discussion
https://forums.ni.com/t5/USRP-Software-Radio/Can-a-single-USRP-2920-tansmit-Tx-and-receive-Rx-at-the...
bhovhann
(2,224 Views)
