From Saturday, Nov 23rd 7:00 PM CST - Sunday, Nov 24th 7:45 AM CST, ni.com will undergo system upgrades that may result in temporary service interruption.
USRP Software Radio
Sending same data through two TXs
I've been struggling sending the same data through two different TXs, one on channel 0 and one channel 1, the VI works for a single TX but when I change the "niUSRP Write Tx Data" block to 2D complex double it doesn't take the data in anymore and displays "you have connected two arrays of different dimensions". I was hoping the data in would just be sent out on both channels. I have tried fixing the problem using arrays and the channel writer both to no avail, but it is possible I have been using them wrong.
I believe I just need an in-line function to send the data duplicated side-by-side so that each channel has a stream of data to send, but I am just unsure how to do this.
Any help would be greatly appreciated,
Daniel
(1,407 Views)
Accepted by topic author dalexander98
Hi Daniel,
The reason you're getting the behaviour you're seeing is because you now need to write a 2D array rather than a 1D array.
When writing for a single TX as a complex double, the input is a 1D array. This is so that you can write a buffer of values into the single channel:
However, when writing for a multi-channel write, you need to change this to a 2D array. This is effectively a 1D array per channel:
If you're just wanting to write the same data through two different channels, you just need to include a "Build Array" function, size this to 2 (for 2 channels) and wire the same value to both inputs of the array function, as in the screenshot above.
Cheers,
Nick
(1,364 Views)
Hi Nick,
Thanks for the guidance, it was very appreciated. The last point you made what exactly what I was looking for, I knew there was probably an array or something I just had to stick in to fix it but wasn't comfortable enough with LabView yet to figure it out.
Thanks again and all the best,
Daniel
(1,359 Views)
Hi Daniel,
No worries. Have you considered looking at the LabVIEW Core 1 course as an introduction to LabVIEW? It's general-purpose use with DAQ so doesn't explicitly cover the use of the USRP drivers but will help you be more comfortable with the LabVIEW environment in general.
Cheers,
Nick
(1,353 Views)
