USRP Software Radio
Samples collected in pc from USRP
Hi, I am collecting IQ samples at the receiver port of USRP-2900. Now, do these sample values represent the voltage levels or is there any any conversion to be done? I am asking this because when I am perform an averaging over magnitude squares of these samples, and taking log of this gives be power in dBfs. I need power in dbm. So, if the IQ values are in volts then (I^2 + Q^2)/(2*R)  can give me power in dBfs. So please let me know if they are in volts and also is R=50ohms in USRP 2901?
(1,320 Views)
Hi, I suppose that the signal that you register with your USRP has no units. To measure the power in dBm-s you need to use a spectrum analyzer.
(1,266 Views)
