USRP Software Radio
Receive-Transmit Loop for Range Measurement Using USRP
I would like to measure the distance between two USRP devices by transmitting a signal from one USRP and using the other as a transponder. The second USRP should receive the signal and immediately retransmit it. By measuring the round-trip time delay, I aim to estimate the range between the devices. I plan to implement this using the B200 Mini and am flexible regarding whether transmission and reception occur on the same channel or separate channels.
I have a few questions regarding implementation:
  1. Can the USRP accurately measure the delay, and is it possible to calibrate the internal delay introduced during transponding?
  2. Is it possible to configure the USRP to perform this function without an external host computer? If so, how?
  3. What range accuracy can be achieved for distances between 200m and 3km?
  4. Is FPGA programming required for this application, or can it be implemented using a host computer via the USB interface?
Thank you for your time and insights.
David
Message 1 of 1
(485 Views)
