USRP Software Radio
Question about USRP Packet TX/RX example ?
Hi , everyone, I have some problems about the NI-USRP packet TX/RX example. At the Receive side, there is a parameter called Acquisition time, which determine the process samples once a time. so if a packet was cut off, the packet would loss, whether I am right?  From the example, we found there always some packets lost even we connect the TX, RX by a cable. So what is the method to solve the problem?  In my opinion , whether can I process only a sample with the matchfilter one a time, whether the cpu can detect the packets immediately and correctly?  Thanks
(6,914 Views)
Hello Hust,
You are correct, there is an inherent synchronization problem because the receiver is not sharing any clocking information from the transmitter.
I believe that this was overcome (I might be thinking of the 6x6 MIMO demo) by creating a small circular buffer that is capturing "pre trigger samples" much like a digitzer. One a certain power level is reached, we say that our reference condition has been met.  A certain amount of samples from the circular buffer is combined with a certain number of samples after the reference condition.
Anthony F.
Staff Software Engineer
(6,881 Views)
Hi, Anthony
 Thank for reply. It is very important for me.
 I am still have some questions about the circular buffer and pre trigger samples,  if the transmitter send the packets quickeyly , whether the receiver can process the samples in time based on your recommend way?
ps: How should I find the trigger condition, can you give some simple example?  Thank you very much!
(6,872 Views)
