USRP Software Radio
Question about MT Demodulate PSK VI
I have an basic problem about  MT Demodulate PSK VI block. I read that recovered complex waveform returns the time-aligned and oversampled complex waveform data after matched filtering, frequency offset correction, and phase offset correction. The frequency offset and phase offset corrections are scalar values applied to the entire block. How could I received pure waveform without matched filtered ,frequency and phase offset inside MT Demodulate PSK VI block diagrams. Would you give me advices please?
(1,599 Views)
Hi ahmetemir,
Frequency, phase offset corrections and matched filtering are integral parts of PSK demodulation algorithm. If you need to get only properly time-aligned and oversampled complex waveform data you should use MT Resample.vi instead.
Best Regards
Leo
(1,508 Views)
