USRP Software Radio
How to transmit bit stream using USRP
if i have for example 101110 as bits i want to transmit using DSB-ASK as my modulation technique..how can i do that ?...a very new labview user here i would really appreciate it if the explaination was by example
the photo below is the digital representation of the bits i want to transmit
(4,643 Views)
Hi Eldokch,
I am looking to see if we have any examples of ASK modulation.
In the meantime, I would check out the other USRP modulation examples we have that will point you in the right direction. They can be found in :
Start»All Programs»National Instruments»NI-USRP»Examples»The version of LabVIEW you are using.
Justin M.
Applications Engineering
(4,609 Views)
