USRP Software Radio
How to send and retrieve data by USRP 2900
I am trying to send and receive frame from NI USRP 2900.
The frame example is FE FE 00 00 00 05 B1 44.
I send the frame with array. I am not sure whether USRP really transmit the data.
How can I check? TX1 RX1 LED is red when I run Transmit VI.
I would like to receive the frame from USRP too but I get 0.
How can  I modify my program? TX1 RX1 LED is green when I run Receive VI.
I take reference from the niUSRP EX Tx Continuous Async example VI and the niUSRP EX Rx Continuous Async example VI.
I have attached transmit and receive vi image.
I don't understand LabView so much.
I am new to LabView and this is my first assignment.
Thank you.
(1,063 Views)
Hi
You should set the tx gain and the rx gain to around 35dB.
(1,028 Views)
Thank you, mikiofuku.
I don't get the result. Still I am trying.
(976 Views)
Hi
You should breaking down the issue into parts. Problem causes rx side or tx side?
You can transmit CW wave from any SG to Rx port on USRP-2900. (to test usrp can receive a CW wave). and you can use any Spectrum Analyzer.
Thank you.
(948 Views)
I don't have spectrum analyzer. Instead, can I use GNU Radio software to check whether transmission is okay?
(826 Views)
