USRP Software Radio
External reference for USRP2
Hello Experts,
I am brand new to USRP.
I have connected analog signal generator's sine wave output (999.999 MHz, -30dBm) to the  USRP2 (ant #2.).
A Rb 10 MHz freq. standard provides reference signal to the signal generator as well as to the USRP2.
I have set the carrier frequency of the radio at 1GHz.
I am trying to see the output of rx_stream. I expected a 1kHz sine wave signal, but I just get a flat line. I have no idea how to fix or debug this program.
Here are the values I have set:
//setup the program options
po::options_description desc("Allowed options");
  ("args", po::value<std::string>(&args)->default_value(""), "multi uhd device address args")
  ("type", po::value<std::string>(&type)->default_value("short"), "sample type: double, float, or short")
  ("nsamps", po::value<size_t>(&total_num_samps)->default_value(0), "total number of samples to receive")
  ("duration", po::value<double>(&total_time)->default_value(0), "total number of seconds to receive")
  ("spb", po::value<size_t>(&spb)->default_value(10000), "samples per buffer")
  ("rate", po::value<double>(&rate)->default_value(10e6), "rate of incoming samples")
  ("freq", po::value<double>(&freq)->default_value(1e9), "RF center frequency in Hz")
  ("gain", po::value<double>(&gain), "gain for the RF chain")
  ("ant", po::value<std::string>(&ant)->default_value("RX2"), "antenna selection")
  ("subdev", po::value<std::string>(&subdev), "subdevice specification")
  ("bw", po::value<double>(&bw), "analog frontend filter bandwidth in Hz")
  ("ref", po::value<std::string>(&ref)->default_value("external"), "reference source (internal, external, mimo)")
  ("wirefmt", po::value<std::string>(&wirefmt)->default_value("sc16"), "wire format (sc8 or sc16)
("setup", po::value<double>(&setup_time)->default_value(1.0), "seconds of setup time") ("progress", "periodically display short-term bandwidth") ("stats", "show average bandwidth on exit") ("sizemap", "track packet size and display breakdown on exit")
("null", "run without writing to file") ("continue", "don't abort on a bad packet") ("skip-lo", "skip checking LO lock status") ("int-n", "tune USRP with integer-N tuning") ;
When I set reference source to "internal", I *do* get a desired output, a nice looking sine wave.
What should I be doing to get a sine wave while using an external ref.?
Any pointers would be highly appreciated.
Thank you.
(4,477 Views)
Hi Kuto,
The USRP2 and GNU radio are supported by Ettus Research, not National Instruments. I reccomend contacting Ettus support for assistance.
(4,468 Views)
Got it. Thanks!
(4,462 Views)
No problem!
(4,456 Views)
