USRP Software Radio
Error- autoload on powerup
I have 2943R. In MAX, when I try to choose "autoload on powerup" for the firmware, I get the error as in the attachment:
There was a problem saving the settings for this device. Error code:BFFA86B3
Is there a way to solve this?
Ozan
(4,575 Views)
Accepted by topic author ozan_icin
The USRP RIO always autoloads on powerup/reboot. The error you're seeing is if you try to change its default value. What's the use-case you're looking to support? Maybe that's already supported?
(4,565 Views)
Thanks for the answer
(4,483 Views)
