USRP Software Radio
Amplitude convergence problem with SBX daughter board
Hello, everyone.
I am trying to measure the relative phase of continuous wave(CW) with N210 USRP. But the problem is when I use SBX daughter board, CW amplitudes slowly converge to zero(like SBX_figure.PNG). But when I use RFX900, this convergence didn't appear.
I used "GNU Radio Companion" and I disabled DC offset correction and IQ imbalance correction in "USRP Source" block. (see gnuradio.PNG)
If you know why this is happening, and how to disable it, please help me.
Thank you.
Whitecloud
(2,518 Views)
USRP N210 is Ettus product.
You should contact Ettus Technical Support Team.
https://www.ettus.com/support
(2,491 Views)
@freeown  작성:
You are right. I should ask them about this, too.
By the way, aren't the NI and Ettus Research same company?
(2,487 Views)
They might be produced from the same manufacturer but I am not sure the hardware is the same.
What I know is that they are running with different software.
NI USRP is running with LabVIEW or LabVIEW Communications software.
(2,483 Views)
