UI Interest Group Documents
ANV Language Support Toolkit
Dear NI community,
let us present our new toolkit - ANV Language Support Toolkit.
ANV Language Support Toolkit is a great tool for localizing LabVIEW applications by translating user interface text to different languages. It is used as LabVIEW add-on and consists of two main parts: configuration part (accessible from LabVIEW Tools menu) and API part (used for integration into source code). With the help of the toolkit, developers can create translations for VIs and distribute them with applications to allow runtime translation.
It has the following features:
  • Create translations for VIs with easy-to-use UI
  • Store created translations in readable text files
  • Translate your VIs with the use of toolkit's API during runtime
  • Translate block diagram strings
  • Validation UI - check, if there are any issues with translation
  • Distribute your translations with LabVIEW applications
  • Full documentation and examples for the toolkit usage
Toolkit is compatible for LabVIEW Versions: >= 2015.
If you have any questions regarding ANV Language Support Toolkit, please feel free to contact us at: support@anv-tech.com.
