UI Interest Group Discussions
vipm error lv2013
When i try to install any package from VIPM for LV2013 i have this error:
but with LV2010 i have not this problem.
This is my Vi Server configuration in LV2013:
TCP/IP: CHECK
PORT: 3364
I turned off the firewall but i have not solve this problem.
How can i do?
Message 1 of 8
(6,909 Views)
This is the wrong forum for these problems. Please post this to the JKI forums. Or submit a support ticket.
Message 2 of 8
(5,750 Views)
Agreed this is not the most apporopriate place to share, but funnily enough I had the exact same issue today.
Peter D
Message 3 of 8
(5,750 Views)
Sorry!!
Pete do you have solved this problem?
Message 4 of 8
(5,750 Views)
That's okay, don't worry about posting in the wrong place.
Unfortunately not, my current project is in LV2011 - so I just installed the toolkit there.  Perhaps the issue is related to having multiple version of LV installed.. but then that (for me) is a story to be explored another day (on another forum page )
Peter D
Message 5 of 8
(5,750 Views)
Accepted by topic author peppe89
There is no problem installing multiple LabVIEW versions. That is not the issue. Here is a link to some ideas.
Message 6 of 8
(5,750 Views)
I've same exact problem: I had been using LV-2012 for a while and VIPM was working great. I recently installed LV-2013. I cannot install any package with same error message. I had checked the support page and I had verified that correct settings were applied.
Regards
Vincent
Message 7 of 8
(5,750 Views)
Hi Michael,
I'm not attacking VIPM, but there is a problem connecting to LabVIEW 2013 it would seem.  I was hypothesising with my suggestion - as I would expect many more people would have reported the issue if it was 2013 specific.
For me I can 'fix it' by adding the WiFi adapters IP address to Machine Access List - this works with WiFi enabled or disabled.  I don't know the security implications of doing this.
Other things I tried which didn't work:
  • Restarting my machine
  • Changing the LV2013 port to the LV2011 one in both VIPM and LV options
  • Restarting again
  • Adding the ethernet adapter address to the list
Peter D
Message 8 of 8
(5,750 Views)
