UI Interest Group Discussions
Transition between tabs in a tabcontrol
Hi everyone,
Attached are few VIs which shows different transitions while switching between the tabs in a VI. Run the VI, use the Enum to change the tabs, and the stop button to stop the VI.
Message 1 of 8
(8,574 Views)
i am quiet amazed, I was using the sliding between tabs but it was not as clever as this I used seperate tabs for every page and then moved their position accordingly
but this one is good with image stuff
Kudos mate !
Message 2 of 8
(5,323 Views)
Please down-version to LV2012.  I could not open the files in LV2012.
-Ajay
Ajay MV
Message 3 of 8
(5,323 Views)
Hi Ajay,
Here are the files in LV2012 version.
Message 4 of 8
(5,323 Views)
Woww.. Great idea with simple technique man.. Keep up..
Ajay.
Ajay MV
Message 5 of 8
(5,323 Views)
Very curious to see the transitions...but unforunately I am using 2010 version of LV.
can u kindly downgrade to 2010 and upload the same VI.
Thank is advance for downgrading.
Message 6 of 8
(5,323 Views)
Below are the VIs in LabVIEW 2010 version.
Message 7 of 8
(5,323 Views)
Thank You for the VI's.
Good One.
RamesH Y R
Message 8 of 8
(5,323 Views)
