UI Interest Group Discussions
Project related to Ticket vendor Machine using Labview
When i run this Vi, I'm getting two errors.can anyone correct these errors please.
Thanks in advance.
(7,944 Views)
This question doesn't relate to the "UI Interest Group" where you have posted it.
Please ask programming support questions in the LabVIEW forum, not in the community groups.
When you ask a question in the forum, those who have time to answer will look at your question and reply.
When you ask a question in an NI community group EVERY MEMBER GETS SPAMMED with your question.
I'm sure most people don't realize this when they post their questions here in an NI community.
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
(5,689 Views)
Hi Chandra shekar,  First Disconnect the Enum from the case structure ,add a new case structure connect it to the Enum, The  Enum elements will appear in the case selector after that drop your code in each case you will get the output.  I suggest you to learn more about Enum and case structure.  Good Luck,  Regards, Krish.
Venugopal
(5,689 Views)
Thank you krish.
(5,689 Views)
