UI Interest Group Discussions
How to make 3D Object Trajectory?
Hi Everybody,
I use the "3D Curve", to display the position data of the data sent by the accelerometer sensor using INS.
I want to show the trajectory of the movement of my tools, and I want the trajectory of the object using the plane for example in order to look more attractive.
I already know how the communication to receive data from the accelerometer sensor. but I have not been able to create a 3D trajektory plane
I've tried to make it with 3D Graph,
precisely using 3D curve, simple coding like this:
https://decibel.ni.com/content/servlet/JiveServlet/downloadImage/2-50479-66529/450-309/front+panel.JPG
https://decibel.ni.com/content/servlet/JiveServlet/downloadImage/2-50479-66530/450-263/block.JPG
but I want the output is not just a line trajectory like above, but also the object plane at the end there. as shown below:
I use photo editing
https://decibel.ni.com/content/servlet/JiveServlet/downloadImage/2-50479-66531/450-309/wanted.jpg
how to make like that in LabVIEW?
i have try customizing with "property node" or properties. but have not been able to like the look of the above, with the object plane F14.
Regards, Thank you
Sugimiyanto
Message 1 of 1
(4,044 Views)
