UI Interest Group Discussions
Feature suggestions for User Interface Manager
Hello All, please post your suggestions for features/changes/bug reports in User Interface Manager in this forum.
Link to UIM: http://forums.ni.com/t5/UI-Interest-Group-Documents/User-Interface-Manager/ta-p/3539490
Thanks!
Piotr Kruczkowski
Certified TestStand Architect
Certified LabVIEW Architect
Message 1 of 24
(14,928 Views)
Hi Piotr,
I just have installed the UI Manager over VIPM, but the UI Manager (UIM Tool.vi) seems to be missing.
Is it wanted like that or where can i find the UI Manager?
thanks in advance
Norbert
Message 2 of 24
(14,564 Views)
It should be visible as another option in the Tools menu in LabVIEW. Do you see it there? Also the package installs a palette into LabVIEW into the addons.
Piotr Kruczkowski
Message 3 of 24
(14,554 Views)
That was too easy.
I was irritated, because in the example project were unsolved dependencies, which told me that the manager is missing.
thank you!
Norbert
Message 4 of 24
(14,551 Views)
DO you mean that the project you had in your examples folder informed you about missing UI Manager Tool? This should not happen. Can you please confirm this and send me screen shots?
Piotr Kruczkowski
Message 5 of 24
(14,546 Views)
I meant the UI Manager.lvproj which has unresolved dependencies
The Project in the example folder is working
Message 6 of 24
(14,540 Views)
Yeah, you should not use that project. It's only used internally. Use only the tools menu and the palette. Good luck with UIM. Let me know if you need anything else.
Piotr Kruczkowski
Message 7 of 24
(14,529 Views)
Hi my name is Niels,
First off the concept of this UIM is great! I do have a question about the interaction with clusters, i pack all my data into one cluster. So every button is in a cluster or in a cluster within a cluster. When i try to use the UIM, it only effects the main cluster property's. Is it possible to effect the buttons within a cluster ?
Thx in advance!
Message 8 of 24
(14,010 Views)
Yes but for this you have to use the API directly. The capture state and apply state methods have an optional input for traversing clusters. Since this is not something that can be easily implemented i didn't add it into the basic tool in the menus. Use the API to capture state and you will have what you need.
Piotr Kruczkowski
Message 9 of 24
(14,000 Views)
Thx for the fast response, ill try it out when i get home asap! Have a nice day, ill keep you posted.
Message 10 of 24
(13,992 Views)
