UI Interest Group Discussions
Customize Variant Ctrl
My customized Variant Ctrls
George Zou
(1,948 Views)
I like these but I won't be using them. Variants aren't really something I want on my UI.  I understand they are useful for debugging, and so showing some variant data on a front panel can be useful.  But in those cases I will opt to use the Variant Probe.  An XControl that looks like a tree but displays anything really.
(1,927 Views)
I use Variants mostly for data transfer.  So they are on the cone pane, on the SubVI GUI.
A classic style Variant ctrl looks awkward among all other system style ctrls.
George Zou
(1,915 Views)
Yes I have Variants on the front panel of some subVIs, but those aren't seen in a built application.  So I'm not interested in putting an effort into making the front panel look any specific way.  If my SubVI could have no front panel, that's probably be fine in most cases.  If you want to have subVI that have nice looking UIs then your controls will work great.  I thought you were suggesting those controls for UIs that the user interacts with.  Which is why I suggested the XControl.
(1,910 Views)
I download and install the Variant Probe.  It looks good on the FP.  But when I try to use it as a custom probe, LabVIEW (2018 SP1 64bit) crash every time.  Guess it meant to be used as a probe.
George Zou
(1,829 Views)
Sorry support for it is nonexistent really and hasn't been updated in a while.  I've used it on front panels for many years, but haven't needed it as a probe for a while.  Last time I used it, it was stable.
(1,826 Views)
No worry.  Thought I should try it since it named as a probe.
George Zou
(1,819 Views)
