UI Interest Group Discussions
3 State Button?
HI Everyone,
This there a way to make a Boolean control (or any other) have 3 states? Example Run/ Stop/ Pause?
And thanks everyone in thise groups my UI's have come a long way from what I learned here.
Message 1 of 9
(15,436 Views)
Hi KPanda,
well, a boolean only knows about 2 states. It simply can't handle more than that Smiley Wink
You can use enums, rings or picture rings to get a 3-state-button...
Message 2 of 9
(9,572 Views)
Hi KPanda, here is an example of a SP3T switch I made some time ago using a picture ring control.
Ben
Message 3 of 9
(9,572 Views)
You can also use a picture control or XControl.  A generic XControl would probably be best, but would take some time.  If you happen to do this, post it.  We get this request a lot.
If your GUI can handle the space, you may also want to consider a radio button.
Message 4 of 9
(9,572 Views)
Check out the 'System Mixed Checkbox'
It has three states: True, False, Mixed.
Not sure how much you can customize the look.
Kurt
Message 5 of 9
(9,572 Views)
I know this was asked for a while back, but you may want to consider making a button that looks like the play pause and stop like a DVD Player.  You can find an example in
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Update-Front-Panel/idi-p/1020307
Make one control Play/Pause, and the other Stop.  This is just a picture, so you will have to create your own.  This is also a standard that has already been adopted, so you are not inventing another concept.  Making all 3 in one button only allows a certain sequence (with property nodes) unless you are allowed to chose from a list otherwise.
Message 6 of 9
(9,572 Views)
I was browsing through the group posts and thought I would put in my $0.02.
By customizing the buttons in a radio control, you can easily accomplish a three-state button control.  A radio control is basically a cluster of buttons, so customizing it is easy.
-Derek Roane
Message 7 of 9
(9,572 Views)
hi everyone!
i encountered the following problem. i managed to replace the three buttons by my custom designs... but when in use there seems to be a problem when the cursor is on one of the buttons... did i miss to replace a "mouse-over image"? if so, where?
thanks!
Message 8 of 9
(9,572 Views)
if you post your code or an example then it's easier to understand what you mean and maybe someone will try to help...
Message 9 of 9
(9,572 Views)
