Troubleshooting Hardware
Roborio 2.0 constant flashing orange status LED
Our team recently got a Roborio 2.0. We followed the instructions for writing the roborio2 image using the Raspberry Pi Imager. Afterwards we were unable to use either Ethernet or USB to communicate with the Roborio. The Roborio's status LED also blinks the continuous orange pattern. We used the roboRIO2_2022_v3.0 image.
(1,479 Views)
Problem solved. The correct image file name for directly imaging the uSD is NOT FRC_roboRIO2_2022_v3.0.zip; rather it is FRC_roboRIO2_2022_v3.0.img.zip. Notice the little "img" in there. The provided instructions say to click the SD folder icon in the imaging tool. And they show the file name pattern you need to look for. But the do NOT tell you that the file you want is the the "SD Images" subfolder of the file explorer window that opens when you click on the SD icon. (Note that this omission in the instructions occurs in both the NI-provided instructions (which are themselves in the "SD Images" subfolder) and the WPILib-provided instructions.
(1,445 Views)
