Troubleshooting Hardware
Roborio 1.0's with bent/broken pins in USB connections
We have two Roborio 1.0's that have broken/bent/missing pins in at least one of their USB connections.
What, if anything can be done repair?
thanks
Jim B
(878 Views)
As a follow up - we also put in an online service request for one of these Roborio 1.0s - service request 02820944
(842 Views)
A follow up to the follow up above - the service request resulted in a $350 quote to be paid upfront - that does not seem correct for NI support under FRC?
Hopefully someone will respond here
(836 Views)
Hi JimB1731,
I'm Matthew with NI.
You are right that the ask to pay up-font is incorrect. They should have pointed you to posting here on the forums where we have FIRST specific support available.
I've sent you a private message on next steps.
(827 Views)
Thanks - and its all good.
I know the FRC requests for support are via this forum, so going direct to NI support wasn't me following process
(819 Views)
