Troubleshooting Hardware
RoboRIO-No Ethernet
Our roborio will not connect over ethernet. We have tried troubleshooting with the same computer/ethernet cord and image on another rio. Initially the lights on the port would flash slowly, but the last few times we have tried, the lights on the port do not show up at all. We are able to connect via USB
(1,208 Views)
For some initial troubleshooting thoughts:
  1. Do the Ethernet port's LEDs do anything at all when you turn the roboRIO on?
  2. Have you tried a different PC to see what the behavior is for connectivity or the LEDs?
    1. I'm assuming we'd see the same behavior as it sounds like you're seeing a successful connection on another roboRIO with this PC/cable setup.  I just wanted to verify
(1,199 Views)
The lights don't do anything when powered on. We just tried a different PC and still don't have connection or lights.
(1,182 Views)
Those were the answers I was expecting.  I sent you a message to help work through a replacement.
(1,176 Views)
